The nut right next to cylinder #4 on the valve cover seems to be stripped and just keeps spinning and spinning. i can't get it off!! anyone ever done this before? i need help!
and also if i just hack it off, would i be able to replace the bolt under? and how hard would it be to do so? thanks.
i can't remeber but i;m pretty sure that the inside (the once next to the spark plugs are number 10, and the rest are 9. I've replaced 2 already, it's very simple
Don't forget when taking your valve cover off you have to put that glue around the gasket. and let it sit for 1 hour (pref 24)
