1 - 10 of 10 Posts
ive was told it is the passenger side piston but im double checking its an h22a4 motor please help thanks!:confused
lol..you must be referring to piston number 1..
If you dont kno where piston number 1 is or what TDC is..well..
no i know what TDC is i was just not sure which was piston 1 if it was on the left or the right if you were looking at it from the exhaust manifold
Piston number 1 is always closest to the pulleys...on any engine.
Yes, #1 is the first piston at the cam gears. Remove the plug there, I have a long small extension that I slide into the plug hole, manually turn the cm gear around to TDC as #1 comes up you can watch the ext move up and down.
1 - 10 of 10 Posts
