i've hooked up subs in a lot of car before but i've never done it with a line out converter. i want to use my stock deck to do the set up. i have a few questions.
1) the grey wires coming from the LOC is the right speaker. the white wires is the left speaker. do i use the grey wires to tap into the right rear speakers and white wires to tap in the left rear speakers??
2) the remote wire...where do i hook this up??? if i hook it up to the battery the amp will stay on right? if i hook it up to an accessory switch what amp fuse should i use?
3) when hooking up the amp will i still have to hook up the 12v battery with the remote wire or will the remote wire provide the amp with power?
