Contact me for camber kit info, questions and pricing. I will take care of you.
www.camberkit.com As for camber wear issues, it is only common sense. Even if your toe and caster are set to zero, if you have considerable negative camber, your tires will waste away at an expedited rate. Its a fact that vehicles with factory negative camber i.e. S2000 (which means the other factors of alignment are set correctly), have advanced tire wear compared to a vehicle like a civic, integra, etc. which do not have factory negative camber.
