Actually you want the ones for the 88-89 Integra engine. They are the same injectors on the ZC - 240cc. Venom's injectors (oem style) flow 264cc - a 10% increase. The part # is HP610-001. These are the ones I am using in my motor. Though I have their in tank fuel pump, I am going to have to add another auxilary fuel pump in line to keep up with the fuel demand of my engine. I am leaning out in second gear (the nitrous hasn't even been turned on yet - waiting to get everything straightened out first). Other parts from Venom that will fit a ZC (I know, I have all these parts on mine)...
Cam Gears - #C10-125 - You will have to machine 2mm off the back side of the gears to get them to line up properly. They are the same diameter and number of teeth as ZC oem gears...
Fuel Rail - # F21-126. It is for an Si engine, but it fits the injector spacing on the ZC. Their mounting system uses adjustable sliding mounts, so it will bolt up to your intake.
Hope this helps.....
