k got a chipped p06, d16a6 mini,me on boost and shift light wired vtec...lol...anyway the damn thing will not rev past 6000rpms wtf? no cels either...is it cause vtec not engaging not allowing it to rev out...anyhelp appreciated.
Zoinks, I wouldn't know where to start with that setup! Did you remove the oil jet from the block when you put the head on? Have you tested the shift light VTEC with volt meter to see if it's activating? What kind of chip is in the P06? Since your VTEC isn't associated with the ECU, it won't be the cause of your low rev limit. Could be the P06 is running stock redline for some reason.
