heres an update on my rex.
i took the spark plugs out and cranked it. my friend said it looked like water was being burnt while i did it so i guess that was it. also when i took out the spark plugs, i noticed on the far right spark plug hole, that i was all brown and had a tiny bit of oil in there. i tried starting it up after cleaning off the spark plugs n shit, but it wouldnt start. it sounded like the distributor was having a problem. so i was about to leave, then i was like, dude im gunna try it one more time. i tried it again and it seemed like it wanted to start, so i was like hmm... so i kept trying to start it and it seemed like it got better each time, so finally after like 6 tries, it started up a lil bit i reved the engine and a LOT of black smoke came out, but i started, and i kept revving it, and it seemed ok to drive home. so i drove it home.
while driving it home, it seemed like it got better. i am burning gas (as usual though because my ECU chip makes me run rich). so i turned it off at my house, then started it up again, and it was fine. it runs like normal.
the only thing im worried about is, my car idles around 500 - 1000.
is that normal?
i havent had my alternator working for a while, i just fixed that problem a couple days ago so i forget where my idel should be.
should i replace my cap and rotor? get my car checked out? any ideas? do you guys think my car is ok?
is that normal?
