i had the same problem that you are having, i did all this, but it didn't help. Advanced the timinmg just a tad, and it solved everything.pushVTEC said:Check the fuel filter, that was my problem. Also like they said check the plugs and maybe replace the wires. Check the rotor in the distributor as well.
As Martinez32 states, I had the same problem and by advancing the distributor about 1mm, the problem was solve.martinez32 said:i had the same problem that you are having, i did all this, but it didn't help. Advanced the timinmg just a tad, and it solved everything.
