Hi
Okay i need a point in the right direction my problem is the map sensor as the map sensor on a honda only reads vacum and not boost pressure how do i setup a 2 bar map sensor i have an safc 2 controller already not fitted just wondering if that can be any use to me or is there another way :)
any info be great
regards james
is your motor built and are you boosting more that 11psi? if not you dont need a 2 or 3 bar map yet...
safc is not a good idea for turbo engine management.. what are you gonna use to control timing?
hi mate the motor is not built i'm only gonna run with 5 psi until the funds r there to get the motor built up just need so info on fuel managment really how would i setup to run boost with stock map sensor and get the ecu too add the correct fuel i have a lc 1 to tune with .
regards
james
