B18c1 - skunk 2 valves/pro valve springs - ferrera valve retainers/oem clips
stock block for now.
jackson racing supercharger stage 3 setup minus the fuel tuning part.
rc 440 injectors
msd external ignition coil.
DEI CryO2 carbon dioxide cryogenic bulb/purge kit.
dc sports 4-1 header to a test pipe tanabe mid section and apexi n1 axle back
excedy street clutch/act fly wheel
koni yellows with ground control springs.
energy bushings
dc sports short shifter
password jdm 4 point rear cross bar
dc sports lower tie bar
dynoed on crome w/ wideband at 235 whp 175 tq
i need a new tune/ tuning system.. im looking in to evans tuning..its my ex g/fs uncle..
no track times i havent taken it out much
its set at 10 psi but i get around 12 most the time.
anything else?:number1
Hey, welcome to the site.
How bout some more details on your build?
What kind of power are you making? What's the powerband like? What are you tuned on? Any results from the track? What other mods do you have on it? What boost level are you at with it?
