I recently switched out my gauge cluster for one with a tach. Everything was fine except my fuel gauge didn't work and my high beam indicator light doesn't come on.( I sourced another fuel level indicator) Luckily I had a buddy doing the same swap so i borrowed his cluster and the light still wouldn't come on. I replaced the bulb and it still doesn't work. Is there a fuse that I may need to replace or maybe a short in the wire. I will check both fuse boxes tomorrow when it is light. Any help will be appreciated.
