Will i see any diffrences if get a FPR and jack up the pressure a little?
0 01preluder · Registered Joined Feb 14, 2003 · 870 Posts Discussion Starter · #1 · Jan 27, 2005 Only show this user Will i see any diffrences if get a FPR and jack up the pressure a little?
V vspec808 · Registered Joined Jun 30, 2002 · 419 Posts #2 · Jan 27, 2005 Only show this user yea and no, it depends on what mods you already have on your car. If you just have bolt on's your better off buying the reg later on down the line
F female four · Registered Joined Jan 29, 2004 · 2,429 Posts #3 · Jan 28, 2005 Only show this user Yeah man, you'd run richer. Only do it if you are running lean.
0 01preluder · Registered Joined Feb 14, 2003 · 870 Posts Discussion Starter · #4 · Jan 31, 2005 Only show this user i wouldn't get any power ut on them?
F female four · Registered Joined Jan 29, 2004 · 2,429 Posts #5 · Feb 1, 2005 Only show this user Power is made when more air and more fuel is added. You need both, not just one. Otherwise all you are doing is changing the A/F mixture rate.
