should be a simple answer question... when i look at most stock HID headlights they have a single projector. is that projector increasing intensity for high beams while being dimmer for low beams or does it stay the same intensity and use the regular halogen lights that are in the headlamp fixture also? I'm sure this directly applies to anyone doing retrofits on their lude
the regular halogen bulbs that are in the headlamps are for the highbeams most of the time. the projector holds the HID bulb for the low beam. that's how it is for single xenon setups..most cars. the projector has nothing to do with the intensity of the high beam.
and as far as intensity goes for a bixenon set up, it's still the same because the solenoid moves the shield down and let more light escapes upward for highbeaming.
so to answer the question. For most "newer" hid projectors, the high and low beam italize the same projector. The difference, as mentioned above, is when the shield moves so it gives more light. They use the "bi-xenon" set-up b/c the ballast/bulb need time to warm up and w/ high beams u need them right away.
I'm using a low beam projector (e46) w/ my oem high beams. Personally i think it looks the best that way on ludes..the other ones seem so big and/or bulky.
thats your opinion of course, but can your halogen high beam any match with my HID highbeam? dont think so ;)
i'm just playin :clap
I also have Rs6 ECE Bi-xenons in my accord :p I know whats hot :)
