1 - 12 of 12 Posts
Honda S2000 Interior LED Conversion Kit
At Diode Dynamics, we carry a full line of LED bulbs, to replace your Honda S2000's map lights, license plate lights, trunk light, turn signals, and more!
Diode Dynamics offers the brightest, highest-quality LED bulb replacements on the market. These LED bulbs are designed by our engineering team here in St. Louis, and every bulb carries with it a three-year limited warranty.
Your S2000's map, and trunk lights use an incandescent bulb from the factory, giving it a yellowish color. By replacing them with Diode Dynamics' LED, you can add a luxurious and modern look to your S2000, with a cool white color, just like the lights on newer luxury vehicles.
The installation is 100% plug-and-play, just replace your S2000's factory bulbs!
Lumens: BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
Diode Dynamics products are backed by a 30-day satisfaction guarantee and a three-year limited warranty.
Questions? Feel free to ask here, PM, email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
1 - 12 of 12 Posts
