1 - 20 of 39 Posts
Check it out.
Courtesey of Honda Tuning:
Propulsion
DART tall-deck B-Series engine block
B16A cylinder head
BorgWarner T-10 four-speed transmission
Quarter Master twin-disc clutch
Custom four-inch driveshaft
Custom rear end, ARP flywheel bolts
R&T Autoworks engine mounts
Skunk2 Pro 1+ camshafts
Endyn CNC porting and polishing
Custom 13.0:1 pistons and rings
Crower connecting rods
Crower crankshaft
Canton Racing oil pan
TWM 52mm individual throttle bodies
Pro-Fabrication Tri-Y header
R&T Autoworks/Pro-Fabrication exhaust
Griffin aluminum radiator
Russell steel-braided radiator hoses
Unorthodox Racing crankshaft pulley
Unorthodox Racing alternator pulley
Unorthodox Racing power steering pulley
RC Engineering 550cc fuel injectors
Aeromotive A1000 fuel pump
Russell Competition fuel filter
TWM fuel pressure regulator
Russell steel-braided fuel lines and fittings
NGK spark plugs
MSD Super Conductor spark plug wires
MSD 6AL ignition
MSD Blaster ignition coil
MSD Pro-Billet distributor
Hondata S300, A'PEXi Power FC
Stance
Pro Shocks coilovers, Eibach springs
Resistance
Outlaw 11-inch rotors, Outlaw pads
Outlaw four-piston calipers
Custom steel-braided lines
Wheels & Tires
15x7 Bassett Racing wheels
26.5/15/8 Goodyear slicks (ISCARS spec)
Exterior
fNO Race Cars tube chassis
ARP aluminum body
Interior
ButlerBuilt racing seats
Woodward steering wheel
Wilwood pedal assembly
A'PEXi EL II System Meters
Link to Feature:
2010 Honda Accord - Canton Racing - Honda Tuning Magazine
lol, fail.
What will they think of next.
Im sure it sounds nice but i think the sideways forces from the bends will eat all the torque that the motor produces,
you'd be shifting down faster than a 1liter car trying to climb a steep hill. :lmao
Discussion Starter #5
well gearing wise they would have it figured out that you are only using like two gears for the track. I looked, I dont know out of how many cause the site is horrible, but he is 5th right now.
I am interested in how it performs against the competition.
my guess is pretty poorly. I mean, the v8's they use in stock car racing are just as built as this thing, and 4 more cyl's = 4x the power and torque. This setup is nothing but a handicap against v8 powered stock cars in teh same class.
Premium Member
i will never even compare to a nascar v8 with the restricters on.....not in hp,tq, or transient throttle response.....you'll need 9 close ratio gears just to help tq multiplication
it's only running 550cc injectors meaning it's putting down under 350whp.......it'll get spanked
Premium Member
chevy monte carlo nascar
Type Chevrolet V8-SB2
Displacement 358 cu. in. max
Compression Ratio 12:1
induction System 4V Holley carburetor
horsepower 770 hp @ 9000 RPM
Torque 530 ft.lbs. @ 7200 RPM
hm, I thought trash-car's were FI, not carbed.
Premium Member
no
NASCAR pondering move to fuel injection - ESPN
BRISTOL, Tenn. -- NASCAR is researching the possibility of moving from engines with carburetors to fuel injection.
Officials met with top engine builders from organizations earlier this month to discuss the move of that technology and others that would make cars more fuel efficient and more like cars on the manufacturer showroom floor.
Manufacturers switched fully from carburetors to fuel injection in the 1980s.
No timetable has been set for when fuel injection could be used, but Toyotas Lee White said his company could be ready to go by the 2010 opener at Daytona if NASCAR gave the go-ahead.
"I would vote for it," White said on Friday at Bristol Motor Speedway. "No question, because everyone right now is spending an absolute fortune on [carburetor technology] that has absolute zero application in real life."
White said all manufacturers need to be more conscious about the environment to survive, and he believes NASCAR needs to move more in that direction.
"Sit in the grandstands and watch these cars go into Turns 1 and Turns 3 and watch all the fuel belching out the tailpipe," he said.
White said the transition could be made easily and without great expense.
"Its something that could be implemented along with a few other things that could be discussed that could potentially reduce costs and increase the potential audience for the sport," he said.
wait wait wait, did I just read twin clutch for a torque-less freak car?
Premium Member
i'm gonna laugh since it's probably slower than most mildly modded street v8's ....haha
interesting article. Wow tho, I'd figure they'd have switched, like every other motor sport lol.
Doesn't Honda make a V8 for the Ridgeline? or is it a V6? They couldn't have used one of those?
Premium Member
2010 Honda Ridgeline
Side-by-Side Comparison
Starting MSRP $28,450 – $34,430 Change Vehicle
Snapshot
EPA Fuel Economy:
City: 15 Highway: 20
Available Engines:
250-hp, 3.5-liter V-6 (regular gas)
Available Transmissions: 5-speed automatic w/OD
New or Notable
What We Like
What We Don't
Unibody construction
Crew-cab body style
Standard 4WD
Excellent V-6 powertrain
Sporty 3-D look for gauges
Three new exterior colors
Discussion Starter #16
lol, its not in Nascar, those engines are very closley scrutenered. You would never get a I4 in there. I stated already that he is 5th our of probably around 20 I would guess I dont know how many there is just a guess, but I do know he is 5th.
I dont think they are going to release its true numbers either.
This thing sounds nuts!!! Just found some vids!
I wonder how dereks engine build compares to theirs with all things considered.
You know, money spent and hp/tq developed per liter.
Premium Member
the car is under 350 rwhp...it's running 550cc injectors....which indicates 260-350whp range
well that means dick all, why even care about hp/tq per liter. meaningless.
Hp per liter is meaningless, but tq per liter is not. All you need for more hp is to spin faster, getting torque without using gearing is much more difficult at a set displacement.
IMO tho, either number by itself be it HP or TQ is meaningless without other information.
Things that matter to me HP/TQ made from what size engine, with what compression ratio.
Simply put: my view is it matters only if you have all the numbers to compare the engines to each other. Then Hp/TQ produced per X ammount of displacement matters.
My favorite example is the Rx8's renesis engine vs the subi wrx's ej20T the RX's makes a LOT more hp, however its tq sucks balls.
The other thing I don't get with that car is that it has a twin disc clutch setup for a small engine that doesn't need that kind of tq handling capacity.
1 - 20 of 39 Posts
