I'd like to see some pic's if any1 has it that is, of a s22 hondata with p28 or any other ecu instaled on 5th generation, im very curious. thanx
It looks like any other ECU, the changes are all inside the ECU on the chip. The only difference for a 5th gen is there will be an adapter harness, which looks like a bundle of wires with plugs on both ends...BerzerkerViP said:I'd like to see some pic's if any1 has it that is, of a s22 hondata with p28 or any other ecu instaled on 5th generation, im very curious. thanx
under the passenger kick panel. pull back the carpet, then there's a metal plate under there, it's under that. So is the ATTS computer on SH ludes.BerzerkerViP said:hehe, just wanted to see a pic in the car, sorry just interested, btw any of you know where 5th gen prelude ecu located? have not ever checked for it yet![]()
I'm not 100% sure on this, cause I've never seen it, but I believe hondata is actually software that is loaded onto a chip that is installed inside the ECU. Not a box like the ECU. Then there's an adapter harness for the OBDI ecu to the OBDII car.BerzerkerViP said:thanx. and if i had hondata instaled there, then that would go there also?
you're not thinking greddy's blue box are you?BerzerkerViP said:Weird iv seen the hondata it self, and its a blue box, but i dont know much about it, im still thinking it would go somewhere next to it...
