anyone know how to hook up a volt gauge? on the back of my gauge it has 3 places for wires... they are in a triangle pattern and in the middle is...
GND
S I
im guessing that is supposed to tell me what wires go where... gnd stands for ground im sure but i dont know what the others mean... any help would be appreciated... thanks...
GND = Ground (i.e. any 'ole chassis ground)
I = Ignition (i.e. any wire that goes hot when the ignition is in the 'on' position)
S = Signal (i.e. a source to measure the voltage. straight at the battery + would be the best choice for the most accurate reading)
No, S is not for the dash lights. A dash light wire is irrelevant to a voltage gauge.
blue2kSi said:
we ran it to me alternator for the power... but thanks for the help
Off the Alternator or to the battery, it's the same thing. That is where the alternator connects to anyhow. So you will be able to see the charging voltage when she's running.
One thing that annoys me about Honda is the lack of instrumentation on the dash. Voltmeter and Oil Pressure would be two really nice additions to the guage cluster.
Discussion Starter · #6 ·
thats true... they are 2 things that most other cars have that civics dont... and they do come in use... they have for me atleast especcially whenever ive gone thru alot of alternators... they should start putting them in there...
I'm pretty sure Honda uses an Idiot Light for voltage, but I'm not 100% positive. I'd have to check my manual. And they do have an idiot light for Oil Pressure of course.
Still having both is the best way to go. It's nice to see all the analog needles moving around when you drive and you really get a good feel for engine as well. I miss those two from my last car, something I might add in the future.
