well spraying, i should be in the 15's, so i wouldnt do it for much longer than 15 seconds. whats EGT? yeah ill definately watch my temp gauge. if i do run it for a whole 1/4, should i let it cool down for a bit before the next run?prelude707 said:I wouldn't spray more then 15 seconds.
But I suppose the real answer is really depending on your setup. Watch your temp and EGT gauge and make sure there's no detonation.
yea read the stickys for some good info. :rolleyesdruuuu said:can i spray for a whole 1/4 mile safely?
even if it does have that function it wont be really accurate w/o a wideband o2.prelude707 said:I believe Venom's system does have that. The other's just spray a predetermined amount of fuel all the time. Your ECU will also add more fuel for the addition air. So generally it is safe. But spray for long enough and I guarantee your engine will get hot enough to do damage. You shouldn't have a problem.
Also, please tell me your using a wet shot.
Remember, Nitrous doesn't kill engines, People who don't know what thier doing does.
