im turbocharged my setup consists of a t3/t4 turbo tial 38mmwastegate,runnin at 6.5psi,tuned with hondata,2.5chargepipes,2.5downpipe,3inchexhaust with 3inch muffler how much am i lookin to gain if i went from 2.5 to 3 inches in diameter?
if it's an internal gate it will tend to creep, but with an external it shouldn't creep much if at all, and for a turbo set up, no matter how many cylinders, the best exhaust is no exhaust. So a 3'' is great for a turbo 4 cyl. You tend to lose low end with a bigger exhaust on N/A applications but with a turbo you tend to spool faster and may actually gain low end.iLLeFFeKt CiViC said:so you're looking to swap out your 2.5" downpipe for a 3" one right?
i would leave it alone for now untill you get a bigger turbo or something.
if you go to 3" now you might experience boost creep and a tad more turbo lag (if any).
you can hit more than 400. it all depends on setup.Mario Aloia said:you could hit 400 whp on a full 2.5" exhaust.. but if you moved to 3 inch from that setup you might see at least 30-40 whp
