the steering column is inside the car. i just popped the hood on my 95 civic d15b7 and its mounted on the top of the firewall in the very center. its a small black metal canister. both lines are easily accessible. you MUST be trying to change the wrong thing. you got pictures? ill try and get a quick pic of it with my camera phone in the next few minutes.goon said:I'm having trouble getting the old fuel filter off. I can't get to the line screwed in underneath the fuel filter and I can't get to it from the buttom of the car because its covered by the stearing column and stuff. Any suggestions?
Id say gimmick. High flow doesnt mean much really, the stock filter can flow plenty. For high flow in a fuel system there are really 3 things, pump, regulator, injectors.FERIO_SiR said:Does it help, or it is just a gimmick?
I can attest to this. I have no idea when the last time my filter was replaced before I did it a few months ago. The old one had brown sludge in it :fear :lmaoksniperfox said:you wont feel a difference unless the old one was so clogged up that it hindered stock performance. change it every 35kmiles or so, part of regular maintainence. not a performance modification.
The filter makes a difference for really high hp situations, but for 99.9% of the people out there, the oem filter is plenty.commador said:Id say gimmick. High flow doesnt mean much really, the stock filter can flow plenty. For high flow in a fuel system there are really 3 things, pump, regulator, injectors.
i got it out of the car just fine......i had to use a vice and bar to get that nut off.....speedjunky01 said:yup thats it Mine was a bitch to till ibusted out the braker bar![]()
kommon_sense said:The filter makes a difference for really high hp situations, but for 99.9% of the people out there, the oem filter is plenty.
Thanks for sharing the knowledge.kommon_sense said:The filter makes a difference for really high hp situations, but for 99.9% of the people out there, the oem filter is plenty.
