How to Convert Video files to PSP Format ?
1.Download the fastest video to PSP converter software at
Video to PSP
and install it.
2. Connect a PSP to your computer with USB cable , start PSP, and select "USB Connection" to connect PSP with PC.
Tip: If it is the first time you play a video on PSP, you need create a directory "\MP_ROOT\100MNV01" on the memory stick of your PSP. For example, if the memory stick is driver J: on your PC, you need create a directory like: "J:\MP_ROOT\100MNV01".
3. Launch Lenogo Video to PSP Converter.
4. Click "Add File" button and you'll see a dialog below. If you want to see the full list of all supported video formats, the check the "Advanced Mode (for more video formats)" checkbox. Select the video file you want to convert, and click "Open" button.
5. This dialog shows the contents table of the the movies to be converted.
6. If you have properly connected a PSP to your PC, when you start Lenogo Video to PSP Converter, the software will automatically detects PSP memory stick video directory which you'll see in "Save as" box, e.g. "J:\MP_ROOT\100MNV01\". It is recommended that you don't change the directory. The software will also create a PSP-ready title which you don't need change either.
7. Now click "Convert" to start converting. The display on the top shows the converting progress. You may also preview the movie in the Preview Display on the right.
8. When the conversion is completed, the result files are in your PSP and ready to playback. If you will convert other movies, select menu "Edit -> Remove All", and then go to the step.
Detail information at Video to PSP
Discussion Starter #2
How to rip DVD and convert DVD to PSP on Mac OS ?
There is no doubt that PSP is a great game player. But it is also a very good video player because it has a pretty big screen compared to other portable video players. If you want to put your DVD movies on PSP, there are many DVD to PSP converters you can find on the Internet. But most of them are for Windows OS users. Despite the limited choices, you can still find some good DVD to PSP converter for Mac OS users, and DVD to PSP Converter for Mac download at DVD to PSP for Mac is one of them. It has an interesting Mac style and is very easy to use. The following three steps are all it takes to convert DVD to PSP with this software:
Step 1: Import DVD Movie
Click the Load DVD button, select the folder of your DVD movie, and click OK. If the movie is on your disc drive, you can just select the drive and click OK.
Or click the Load IFO button, open the folder of your DVD movie, and you will find two folders in it: AUDIO_TS and VIDEO_TS. Open the VIDEO_TS folder, select all the IFO files, and then click OK.
After the movie is imported, you can see all the chapters and titles in it, and then you can check the ones you want to convert. If you want to convert the whole movie, you can just keep all the titles or chapters checked.
Step 2: Output Settings
Before the conversion, there are a few settings you should make:
A. Select the PSP Video format from the Format drop-down list.
B. Click the Settings button to set encoding settings including video resolution, frame rate, bit rate and video encoder, audio encoding settings including sample rate, channel, bit rate and audio encoder.
C. Name each title/chapter in the Output Filename field, and select the subtitle and audio track for the titles/chapters.
Note: You can check the “Merger into one file” option to join all the selected DVD titles/chapters into one file instead of creating a separated file for each title/chapter.
Step 3: Click the Start button to start the conversion. And now you can just go talk a walk and wait till the conversion is completed. After that, you can just transfer the created files to your PSP.
Tip 1: Trim Movie
If you just want to convert a clip from your DVD movie, you can click the Trim icon to capture a clip. In the Trim window, you can trim the length of the current title/chapter by either dragging the Start Time and End Time sliders or setting the time parameters in each corresponding field.
Tip 2: Crop Video
If you DVD video has black sides, you can use this Crop function to remove them. Click the Crop icon to open the Crop window, and set the crop area by dragging the crop frame or setting the four crop parameters (Top, Bottom, Left and Right).
Tip 3: Movie Effect
If you are not content with the original effect, you can click the Effect icon to set the video brightness, contrast, saturation, and audio volume. You can also choose to apply a special effect to your movie video from effects including Gray, Emboss and Negative.
More information at DVD to PSP for Mac
