I have received several emails on this as well, so here it is the install directions. I do reccomend the genuine S2000 button as opposed to the Ignited one because it is cheaper. Plus it is better quality and nothing beats the real thing.
You can get this at your local Honda dealer. It is part #35881-S2A-911.
Here is the pin layout:
Pin #1 is the signal wire.
Pin #2 is power.
Pin #3 is ground.
Pins 4 & 5 are unused.
You will need some pin connectors to connect the wires to the pins. Buy about 1 foot of black wire for the ground, about 4 feet of red wire for the power, and about 2 feet of yellow wire for the signal. (you don't have to have different colors for the wires, but this might simplify things greatly)
The power wire must be attached to a source of 12V power. DO NOT attach it directly to the battery w/o a fuse!
You can hook it to constant power if you want the light on all the time, or switched power if you want the light to come on only when the key is on accessory.
The signal wire connects to the wire that sends the siganl to your starter to start. This is different with different vehicles. Your stereo shop will tell you what button it is on your car. I'll let you 5th G guys know which one it is as soon as the Lude gets back from the shop.
The ground wire connects to a solid piece of bare metal in your car. (dUh!)
Thats it! Remember because of the immobilizer system the key must be in and turned to acc. for the car to start. Manually equipped cars must have the clutch depressed.
Please post up or PM me with any questions.
Pin #2 is power.
Pin #3 is ground.
