my right back light is full of water drops and i wonder how to get them out. i beleive that water got in because there is no fog light installed at the right side so the light isn't watertight. i want to make it tight but first i have to get the water out... so anyone help me please!
I had access to an air gun... works like a charm... takes about 5 mins...
after you do that use clear epoxy and look for the hole in the light... i found a small separation where the lens joins the plastic frame... i've found that all the APC lights that i or my friends have installed come accross this problem at one point or another...
-Henry
Discussion Starter · #6 ·
well, thanx guys.
i don't have altezzas so i don't have to burn them ;)
i'll get a blowdryer and see what i can do. maybe i don't even have to take them off... or do i?
You could probably go in from the trunk to blow dry them.
It would be easier if you took them out to re-seal them. It's not difficult taking them off, just a few screws. :)
