ok, so i bought a stabilizer brushing kit (1 huge "o" ring and 1 rectangular thing). im wondering where to actually replace it. from under the car? is it pretty easy to do? im guessing its along the same lines as putting in a short shifter. any help would be great. thanks! its a 94 integra ls
If you installed your short shifter, you should be fimiliar with under your car. Right behind your shifter, is where the rectagular one goes. There is a stock one that looks just like it. And then follow the arm until it gets to the tranny. And the "0" one goes there.....Its very simple to do and it makes shifting feel much better. Good Luck!
Oh by the way, us soap on the hole on the bushing to make everything slide into place....its a tight fit.
thanks for the help. i got the first one installed but im having trouble with the big "o" ring. do i have to completely disconnect the arm to the tranny first? sorry for sounding like an idiot 'cause i dont get under the car a whole lot. thanks!
