Ingalls makes the front camber kit with ball joints and without.
Ok, that clears up a lot of this!
Of course the kit with the ball joints will cost more.
Kind of figured that. Know about how much more?
If you buy the kit without the ball joints, you will need to be careful not to damage the old ball joints and the rubber boot when you separate the A arm and the ball joint. You will also need a press to separate the ball joint from the A arm. Some people have sucess using a large socket and a hammer. If your car has some mileage, you might as well buy the kit with the ball joint because your old ones might be worn. It just makes the job a lot easier.
I think I'll buy the new ball joints. Car has 44k on the odometer, but I know I'll break the old ball joints when trying to remove them. Plus I'd rather get new ones.
Any speed shop that reps Ingalls can help you. Ps, the kit is also available with stock type rubber bushing or the high performance polyurethane bushing. The rubber one will be quieter and wont squik but not as tight. I picked the rubber for the front and the poly in the back. I have to grease the back ones every two months also. I hope this is not too long.
If the rubber are quieter why would anyone buy the high perfomance bushings? High performance bushings would cost more right? What is the difference, besides the high per. ones need maintenance every coulpe of months?
