1 - 13 of 13 Posts
I need help ASAP. i was offered by some guy a hood(carbonfiber) for my del sol. He says less than $100, he also says its in a good condition. I got a bit suspicous considering that they cost a lot. Now if i go check it out what should i look for? if its real or fake? Help WANTED. Thanks
im not to sure.. but i would see how heavy or light it is
Discussion Starter · #5 ·
OK, but the bad thing....i dont know how much a stock hood weights or how i should compare them. anyone know about how much a stock hood weights
you should be able to see the fabric weave of the fiber on front and back side. as for weight you should be able to get a decent estimate just by lifting it when its in place. don't think i've ever seen a fake carbon fiber hood.
  • Like
Reactions: 91Vtec
Discussion Starter · #8 ·
k, i try those out. thanks. i hope i dont get riped off. Another thing he says it was for a 93, it should fit my 94 considering its a del sol?
dude........ ive never heard of a fake CF hood......
look at it, you can see into the gelcoat and be able to see the CF weaves in and out of eath other......im sure its a real cf hood.....
dif in quality might be the cost discrepancey
look at the edges..they should be rolled not cut
and the supports under the hood should be pretty sturdy
Discussion Starter · #11 ·
Gotcha, ill do that. When you mean rolled you mean rounded, so if i see a jadged edge(not the singer) than i should reject it or at least get it cheaper?
All the CF hoods i seen are 90% Fiberglass with a layer of CF over it. VIS makes damn good hoods but look closely under and its all cross-matt Fiberglass. But any light weight hood for under $100..... GEEEEEEEETTTT IIIITT!
agreed........you cant beat the price...even if its kinda a POS
and yes when i say rolled i mean rounded off....it should have the CF wrapped around the edges.......although i doubt you will be getting a very good hood for 100....it will probably have cut edges and only have CF on the outside
1 - 13 of 13 Posts
