question one: whats the best way (besides CAI) to keep your engine running cooler, and air intake cooler, i know wrapping the headers, smog pump (while not good for environment )to replace PCV, rerouting coolant to bypass throttle body, and good air circulation in engine cabin. i have heard about coating the air intake (and possibly throttle body/manifold) with a heat resistant paint. now that being said question two: if coating, what parts should i coat, and with what. i have ceramic red caliper enamel and black engine enamel. could i put a base of the red to protect against heat and then put the black on for looks? from what i heard unless i got it backwards black-reflect white-absorb. but i wonder if the coating will just keep heat in. any comments and suggestions would be awesome. also i heard of a hondata heatsink. only problem i didnt see one for the crv or my engine. ill double check, right now i have a fel-pro (looks like ) graphite intake gasket how will that do with heat transfer?
