You have to remove the headlights and get the screw fasteners (not sure what they are called) off also.... did you get that far? You can do this sorta without taking the lights out.... but its a pain in the ARSE!!! hope it helps
Dan
I found it easier to take off the beam that the bumper is bolted to. There are 6 bolts holding the beam on. 4 can be accessed by either turn signal lenses, you'll need an extension on the rachet. The other two are on the front inside of the engine bay, these are the hard ones to get cause there is no room, should be just to the outside of the headlights with a long thread.
Taking the whole beam out with the bumper makes it easier to get to the screws that are underneath the headlights. This way, you don't have to take those out. Hope this helps :)
