From what I understand the cpu relearns your car every so often to make sure it is still doing its job. So when you install a new mod all have to do is let is sit for a while idling and it will relearn the car.
dwnthehatch said:
Quoted from the Helm manual:
1. Turn the ignition switch off.
2. Remove the BACK UP fuse (7.5A) from the under-hood fuse/relay box for 10 secondsto reset the TCM or PCM.
3. Turn the ignition ON, and set the radio presets.
Where did you find that in the Helms??
I am going to check my Helms in the morning and reset my ECU!
>>> Installed an AEM c/a/i today :)
