How do you tell the difference cosmetically between a b18c, c1, c5, b16's and most well known honda engines out there?
Check the code on the engine. The valve covers won't tell you anything. For example, a Type R valve cover can fit on a GSR. ANd many people do this. So you can be fooled if you look at the valve covers. Also, pay attention to small details. For example, the guy has a B18A or B and the valve cover says DOHC VTEC. Pretty safe assumption that the guy has a LS/VTEC or CRV/VTEC conversion.tegragsr01 said:the easiest way is to look at the engine code but you can tell by intake and valve cover color and the way it says dohc vtec
i agree to a degree w/ this one. the intake manifold is one easy way to tell. i mean especially when comparing a GSR to a Type R.tegragsr01 said:the easiest way is to look at the engine code but you can tell by intake and valve cover color and the way it says dohc vtec
I agree. Besides looking at the engine code as I said before you can look at the intake manifold. If the body of it is above the 4 runners coming off then it is a LS or Type R. If the 4 runners are above the main body then it is a GSR engine.LsVtecR said:
now unless they have an aftermarket one your best bet to tell the difference would be the intake manifold. now the ITR manifold and the B18B manifold are similar looking. but the LS one has a steeper arc than the ITR one.
you are almost right w/ when you say the B16s VTEC is bigger than the DOHC. but the first gen B16 was the opposite. the DOHC is bigger than the VTEC, i would know cause i have a 90 B16 head on my LS.TheX-Man said:I know the covers can be changed but isn't the b16 have the VTEC bigger then dohc, while the b18c has DOHC bigger then vtec? How could you tell between the h22? I mean its bigger, but I didn't realize when I saw a swapped civic what type of motor it was... My friend had to tell me.
look not everyone knows where the hell the engine code is on their honda engine. w/out giving the engine a full body cavity search and just giving it a quick glance i think the easiest way to tell the difference is the intake manifold.just chillin said:looking at the intake manifold won't tell you the difference between, for example, a b16 and b18c5. like 20 people have already said, looking at the engine code is the only way you should identify an engine.
if your good you can tell the difference by just looking at the intake manifold.![]()
