I'm planning on replacing my front disc and pads on my 2008 crv.
Is this hard to do? I'm handy with tools.
What tools do I need so I can be prepared?
Is there a how to section?
If you are aware of performing maintenance work on your car and have done tweaking before, then it is quite an easy task. You must have a suitable jack to lift the vehicle while working on the pads. An assortment of open and closed end spanners, with the universal Philips screwdrivers and pliers should be good enough for tooling. You could view the DIY pages (in the sign) to view a detailed DIY structure for the 2008 CR-V, I too take tips from this portal while maintaining my cars.
