I had a epox ep-8rda+ that shit the bed and I had a Thermaltake HS SLK 800u that mounted by bolts through the board. This is a nasty HS, but I don't know if my current Mobo can use it. This is a socket 462 and doesn't have holes through the board(MSI Kt4A-V). It has to be mounted with that clip that goes through the HS and you need to push down with a flat head.
So my question, what HS/Fan combo would you recomend that is not going to break the bank. I don't really feel like spending more then $30 bones. I have 6 case fans and I have a amd 1700 OC @ 1.7. The temps right now are saying 47C on average, but I set the alarm to go off at 50C.
Hope this helps.
Hope this helps.
