i have my 94 teg lowered about 1/2 fingure gap in the rear and i just bought a set of wheels 205/45/16 and and i put two washer on the upper control arm behind both screws on each side to adjust my camber. when i push down on the car on jack the cars tire into the wheel well it doesn't rub, but only when i make a left hand turn the tire rubs real bad. over the winter i hit a curb doing dough nuts but not real bad didn't even mess up the wheel cover not sure if maybe that made something loose or what. but like i said it fits in the wheel well perfect and with room to spare. when i make a right hand turn it doesn't rub, so if any one can help please do.
You should see rubbing marks on your sidewalls if your tires are really rubbing. So check that first.
You can try to roll the fender to get more clearance so your tires won't rub. If that still doesn't work, then your set of wheels might have incorrect offset.
yeah i see the marks on the tire and i here it rub but it is only when i corner left not right, it is only happening on the pass. rear not the drivers rear. everything clear on bumbs and stuff like that just when i turn left. some how the top of the wheels tips out and starts to rub. but don't know why. this sucks.
