ismael-robert said:
Well don't quote me on this, but if you're going turbo I don't think you'll need valve springs because turbo cams are practically stock cams. You may not even need to buy new cams. If you're going all out though with bigger valves and all you may want to ship your head out and have a Port and polish job done and they can install your valves for you (about $900). In the transmission you may want to throw in a LSD and light weight flywheel.
thats not true
u need a strong cam and not just cam u need strong head. how that!
i will tell u
if any body want 500hp like what i want
u need research about how u can get it and thats what im doing
so if u need 500hp u need big valves if u need big valves u need seat valves and guide valves if u get it u need dual springs if u get all head things then u need cams a good and strong cams and now u end the head and go to the block stroker kits with sleeving thats will be ok
and just need a turbo
what im doing not buy every thing i just buy every thing i know and learnnig about it and then buy it
i know u cant understand me because my language im from kuwait and know a little english
