Discussion Starter · #4 ·
RedlinedDA said:
you're putting a b18 in an accord?
and to the left of the exhaust manifold there is a small square section that will have the motor code stamped there
I already got a b18 in the accord, just havent took a look at it yt, its been at my uncles im getting it tonight. will it say b18** whatever?
As for the turbo kit, it is probably meant to fit properly in the engine compartment of the car whose engine it was originally built for so if you did an engine swap a full kit is probably not the way to go. Besides, in my opinion, a full kit is never the way to go. If you've got the green, custom build your own turbo system so you can fit it in the car the way you want and get the exact efficiency and powerband you want. :)
