Here's my problem.... when I start my car.. the idle will be high of course. The abnormal idle doesn't start till my car has warmed up and I'm at a stop. When I'm at a stop, it jumps up and down... from 750 rpm up to 1800 rpm nonstop.
I did a search and I ended up changing my thermostat and cleaning my iac valve. After that, my car worked perfectly for 2 days. All of a sudden, it started again!
How come it worked fine for 2 whole days? The thermostat and iac seem to fix the problem for a little bit.. Can anyone please help me! THanks!
Super Ban-Finger Mod
you have to adjust the screw inside the iac.
did you see like a white plastic screw behind those plates? you gotta ajdust that
