my car is idleing high. Like around 2 grand. its a 88 crx si with 92 ls swap. I have no codes and no apperent vac leaks.
If u want to find the vaccum leak. People would try to spray carb cleaner on various components while the engine is running. When you spray a component (hoses, TB gasket, IM gasket, etc.) and you notice a difference in idle, then thats were the leak is.nycehonda said:Check you pcv valve. and if you have a vacume booster check that
