whats causing my prelude vtec to idle up and down
D deadair · Registered Joined Feb 15, 2005 · 4 Posts Discussion Starter · #1 · Feb 15, 2005 Only show this user whats causing my prelude vtec to idle up and down
S spray004 · Registered Joined Aug 20, 2004 · 4,479 Posts #2 · Feb 15, 2005 Only show this user deadair said: whats causing my prelude vtec to idle up and down Click to expand... Check engine light on?
D deadair · Registered Joined Feb 15, 2005 · 4 Posts Discussion Starter · #3 · Feb 15, 2005 Only show this user i wish but nope its not on
S spray004 · Registered Joined Aug 20, 2004 · 4,479 Posts #4 · Feb 15, 2005 Only show this user deadair said: i wish but nope its not on Click to expand... What rpm range is it fluctuating between?
D deadair · Registered Joined Feb 15, 2005 · 4 Posts Discussion Starter · #5 · Feb 15, 2005 Only show this user if the engine is cold it'll rev up to around 3200 and back down to 900 over and over and when its warm it'll only rev up to about 2500
S spray004 · Registered Joined Aug 20, 2004 · 4,479 Posts #6 · Feb 15, 2005 Only show this user What year prelude? Could be a number of different things, idle air control valve possibly. MAP or MAS depending on what year prelude?
D deadair · Registered Joined Feb 15, 2005 · 4 Posts Discussion Starter · #7 · Feb 15, 2005 Only show this user its a 93 prelude vtec
S Snoopy · Registered Joined Jun 14, 2002 · 5,517 Posts #8 · Feb 15, 2005 Only show this user sounds like a possible vacuum leak or bad iacv.
E explosivpotato · Registered Joined Aug 5, 2004 · 173 Posts #9 · Feb 16, 2005 Only show this user check timing check the timing belt/position. I had an uneven idle and pinging at low rpms when my timing was bad.
