when changing ignition timing the helms manual says to disconnect a connector on the right side of the engine bay and connect a jumper wire to the brown and green white wire's on the connector. So my question is if you take the connector apart, there's a brown and a green/white on both sides. so the brown wire on which side of the connector to green/white on the same side or the opposite side and is it one brown green/white connection or both on both sides. Im confussed Please help.
Dont you just short those wires out, i dont know, you're talking about a 4th gen, on the 5th gen there's a connector behind passenger side kick panel, you just short it out with a paper clip...
