The full monte baby.... 18lbs lol I dont know... ill ask lars when I talk to him though...
you can more than likely get him at www.d e zo ri s.co m take out the spaces
Hmmm that would ride out cause it doing damn good at 8psi.blkDOHCsol said:pending on proper fuel setup- id say 15lbs, maybe turn it up a hair at the track, if you aint satisfied.
MX-5's of the same CR can run around 15psi - ish, so with built bottom end you should be looking at that I would've thought...Slow_Arse_Sol said:How much boost can my 1.5 handle? Didnt you say you had a turbo 1.5 at one time? My bottem end it rebuilt. SRP pistons 9:1, Crower rods, STR sleeve saver, etc. What you thinki could run safely?
I have the MSD BTM and a fuel pump. You recommend injectors, and a stand alone? What else. I got a fuel rail coming.IntegD said:the 15lbs was sorta gettin too balzy..you need some injectors, BTM,ignition at least..lots of people will tell you that over 12lbs you NEED a standalone..so id stick with 12lbs and then you can boost higher at the track. Just because your bottom is build dont mean it wont break if your leaning out. Im gonna help my friend rebuild (#4 on his car) cause he melted some JEs leaning out.
sorry that was me on my friends sn..as for running 15lbs with no standalone....you need to get a different disk for your FMU, (i assume your running 12:1..cause 12psi with every lb of boost @ 15psi is 180ish MORE psi than stock, this will cause your injectors to sieze Id run some 440s and like a 6:1 or 8:1 disk..hondata is alot of $$ but people on other web boards say you really need em. (www.honda(dash)tech.com) the FI forum is really good. If you run 12psi with no standalone I personally think you will be fine...but its not my motor if it blows..once your setup, go tune somewhere where they have a wideban o2 sensor..good luck dude.IntegD said:the 15lbs was sorta gettin too balzy..you need some injectors, BTM,ignition at least..lots of people will tell you that over 12lbs you NEED a standalone..so id stick with 12lbs and then you can boost higher at the track. Just because your bottom is build dont mean it wont break if your leaning out. Im gonna help my friend rebuild (#4 on his car) cause he melted some JEs leaning out.
