if you have hondata s300, it should be no big deal to get bigger injectors, as that system allows for those kind of upgrades, but you HAVE to tell it. It cant figure it out on its own. Although this upgrade is prolly not necessary (bigger injectors) maybe they are tellling you because the saftey margin is too small. unlike the stock honda sytem which is 95 or 100% injector duty cycle ( you use the max flow of your injectors) most tuners will use roughly 80% or less, depending on theapplication. That extra 15cc rate might increase the saftey margin to what the tuner thinks is necessary.
I advise you to ask your tuner why you need the upgrade, and ask questions about things like saftey margin. They would be happy to tell you, I would imagine. Its not a huge deal on NA apps, but since a turbo can fluctuate its boost depending on how you drive it, that safety margin needs to be increased along with it
sorry for the long post
