J.O.A.T said:Will DSM 440cc or DSM 450cc or RC 440cc injectors plug and play for my y7 (ODB2)? If not what injectors that a 440cc or 450cc will. I am going to control it with a SAFC hack.
Thanks,
Matt
Thanks,
Matt
Yea. Thats why I was wondering. I dont want to use the resisotor if I dont have to. Is there any injectors that I can get that will just plug and play, size 440cc - 450cc? I might be able to go smaller than that. Its only going to be a T3.ginyu6869 said:Are you going turbo?
klungemonger said:I think for the AFC hack you do need 440cc or 450cc so you can properly tune off boost and on boost without throwing a code. The AFC can cut up to 50%, so you use injectors that are nearly twice the flow rate and tune idle/off-boost at nearly full cut. This will let you stay in fuel-cut mode when you tune for boost. That's a shorter duty cycle on the injectors, plus I heard you have to use cut with the AFC or you'll get a CEL.
:giggleklungemonger said:You know that's not my style...just trying to be Helpy Helperton!
