I'm a truck/ offroad guy, but picked up a bought a bolt-on built D16Z6. It's N/A and has stuff like a cold-air, Intake Manidold, MSD ignition (6AL W/coil, cap, rotors, wires, NGK plugs (type unknown), exhaust manifold, exhaust, and a prgrammed ECU.
The issue I have is that the car seems to lack power, it's just not where it should be when you get on it. To compare, I picked up my wife a bone-stock '03 Civic EX from an old lady... Side-by-side it was basically a dead heat.
I was told that the car had non-VTEC injectors in it (it's aVTEC motor obviously). Now from what I can tell, a non-VTEC injector is in the 175(cc?) range and the VTEC injectors are around 225. I think this may be having something to do with it. (Please confirrm)
Continuing, my brother in law has a '95 AWD Eclipse. Apparently it has 450(cc?) injectors, but is changing to a bigger turbo and apparently building his motor. He offered to give me his injectors, but he's not sure if/ how it would work.
Would these essentialyl throw WAY too much fuel (and run retardly rich), or can I have the ECU modified to run these injectors (shorten injector pulse or soemthing)?
Sorry for the long read, just wanted to paint an accurate picture.
Thanks for the info!
