Yeah but there would be no point in buying a hondata setup if all you had in the car were larger injectors.....2point6 said:I use 440cc on my H22a with the stock ecu. I would suggest using a field or an APEXi fuel controller. The ecu does have some issues controlling the injector as idle as is it really rich. A hondata set-up would cure this.
What, I don't know what you mean rudeskawn... Why the hell WOULD anyone just put larger injectors in without other mods? I Looked at the guy sig and based it on the fact he is running boost. If you are directing the question to me, read my sig.rudeskawn said:
The way I understood that was....you have larger injectors on a stock engine. Correct me if I was wrong.....also, what the hell is in your sig that you wanted me to read?2point6 said:
Reguarding the control, issues, The APEXi and Field units can only compensate when the ecu is functioning without the o2 sensor.(closed loop) In other words wide open throttle. The APEXi unit can control partial throttle to a point, but the the ECU takes over and makes corrections based on the 02 readings. this is why a stand alone ECU such as the hondata was suggested.
