My car is in the shop now and for some reason, the injectors are not getting the signal to feed the gas. I had to change out my key ignition because my other one fucked up on me. Now, my car turns over, but doesn't fire up. What could possibly be the problem? Is there any way I can go around the immobilzer system?
_______
DEI makes a harness to go around your immobilizer system. Use a multimeter to make sure that the fuel rail is getting the signal to fire up the injectors. If you changed out your ignition then the ecu is still looking for the signal from the other key. Is a little green key blinging at you when you crank it?
