Is it hard? Is it really anything but changing hoses, and the radiator? do i need to bleed anything or turn anything off? what exactly do i need to do to accomplish this. also i bought a fluidyne radiator, and it needs a smaller fan to fit, so anyone know how to install that as well? thanks...
just unbolt the shrout and the radiator, drain all the antifreeze out of it and remove all the hoses,make sure you unbolt the battery.pull it out and put the new one in it's that simple,i could do it in about 30-45 mins.don't put all antifreeze in it put 50/50\
good luck
write me if you have any trouble
And if you can mix up the 50/50 mixture of antifreeze beforehand it is easier to know how much you are putting in, and it is the best way to make sure the ratio remains 50/50.
