well i put on indigo gauges and the wires run from the top of the faceplate. the problem is that the other plastic peices that fall over the gauges won't clip on properly and thus leaving gaps. Now when i turn it on @ night, the light from different section(e.g. brakelight) seeps into the other ones(e.g.seatbelt light). I need to know how you guys run the wire when doing this so that the peices will clip securely.
you have to cut a lil section out of the cluster to make the wires go thru, like a lil notch...
