vtec4 said:
I bought it a few weeks ago and now I have time to put it in. Anyone having problems with it that I should know about?
just make sure you don't over torque the bolt on the shifter itself, use a LOT of silicone lub where that rubber piece goes on the shifter itself, and on the bottom of the ball thingie, and you can remove that heat shield from the exhaust....
Yeah, be sure to remove the heat shield from your exhaust pipe or your shifter will be banging against it while you drive down the road and drive you crazy... Otherwise, it's pretty straight forward!
BTW, I thought I'd be an ass and tell you --- you should have bought a SKUNK2 Dual-bend shifter... :D
