Well I broke the needle on my temperature gauge trying to put a set of indiglo gauge faces on. They were suppose to be for my year CRX dash that I have (88-89). The gauge faces they set me were for a 88, which is different than an 89. Mine has the seatbelt indicator between the temp and fuel gauge. Trying to stretch the gauge over the needles is how I broke it, seeing how it didn't fit properly. The outer visor is the same for 88 and 89, but the mounts for all of the gauges are different and the screw holes don't line up unless you modify the hell out of the gauges. I went to the junk yard and looked at a lot of different year CRX gauges. 88's are different than 89's, and 90-91 are different than the other two previous years along with a different dash visor, but same cluster mounts. The question I have is - will a 90-91 CRX cluster work in an 89 CRX? I was able to get the entire 91 instrument cluster and visor for $35. I know the dimmer switch and rear defroster switches are different, so will have to rewire them to match up to my wiring, and the hazard switch will not be used in the cluster, so I will just block it off. Has any one done this before, switched years of instrument clusters? Thanks
