1 - 8 of 8 Posts
I was reading other threads about intakes / filters and a bigger filter matters? or what it is made out of? What is the deal with those new filters? Different styles; domes, cones, heat shields?
Eh.... and the material...? sponge like?
bigger filter = more surface area = more air flow
As for material, always go for a K&N filter or equivalent - it's the most efficient and requires the least maintenance.
yes but no...the K&N flows better than stock but doesn't protect against dust particles quite as well. A foam filter flows better than K&N and stock but also doesn't protect from dust particles as well :) The K&N is also very good because it is made out of cotton, is durable, reusable (filter recharger kit) and has a million mile warranty
Discussion Starter #4
haha
damn i love seeing those pics... makes me laugh my ass off
is that a hamster or a chipmunk?
Re: haha
thank you!! It's a chipmunk
Discussion Starter #6
still what is the deal with those heat shielded filters?
and uh.... should i just get a new filter or a whole new intake system? and if the pipe is "fatteR" does that mean more air intake?
colder/denser air taken in = more power
thus a heat shield keeping engine heat away will give you better performance (how much more performance depending on the application) Another way to avoid heat is a cold air intake sucking air from outside the vehicle. On a stock civic cold air will give you something like 4-8 more horsepower.
Also K/N claims filtercharger does not allow fine dust particles to go through because the dust sticks to the oil compound.
Discussion Starter #8
thanks man i appreciate your reply:D
1 - 8 of 8 Posts
